Yes. If hard water build up is blocking the nozzle. Or you could unscrew it, wearing rubber gloves, poke paperclip or pin through to clean it, then rescrew on. Reminder to pump air into container to get max power.
Yes, but why? Just take it off, tap it sharply on the blunt end and most stuff will fall out. If not use a small wire and poke it out from the front.
SOURCE: Weee killer leaks from my Gilmour sprayer finger
Im pretty sure that is all it is. The pressure is by how many times you pump it up. Its just on or off. Sounds like It needs to be cleaned real good, and put soap in it befor you put it bak together. Also there is a screen if you hold the handle and turn the trigger part and unscrew it.
Testimonial: "Thanks for the reply Bigdex!"
SOURCE: herbicide sprayer stopped working
sometimes the tube/straw on the inside of the sprayer where the water comes thru falls off its connection.If you put the end of the hose in the sprayer you may have knocked it off.Depending on sprayer it can be easy or a pain to put back on
SOURCE: Clogged and can't get the weed killer to pass through the power wand
Spray warm or hot water through unit until it unclogs. It worked for me.
SOURCE: I have used Roundup weed killer in the past, and
I have a 5ltr can of Roundup and the dilution ratio for general week killing is 1 part Roundup to 4 parts water. I use this ratio all the time and it workes a treat.
