Question about Roundup "" Weed & Grass Killer
Proper mixture ratio for roundup weather max commercial grade.
Ratio of roundup per litre of water for killing weeds & grass. Commercial grade weather max roundup being used in an 8 litre hand held sprayer.
Posted by robert_brude on
  • Anonymous Mar 15, 2014
    mixing ratio in ml to liters
  • Anonymous Mar 31, 2014
    I want to know the Ratio
Anonymous
    New Friend:
  • 15 Answers
2 ounces per gallon. you can convert gallons to liters on the net.
Posted on Apr 19, 2010
How many Ml of Roundup (380) to10 Litresof water?
Depends on what kind of weeds, but for most broad leaf weeds 20mls of roundup per litre of water is normally plenty. i.e. 200mls for 10 lits.
If you have couch that you are trying to kill you should triple the amount and possibly spray it twice.
Sep 17, 2011 | Roundup "" Weed & Grass Killer
I have kukuyu grass growing around my vegetable patch and I want to kill a patch of grass 30cm around the veg patch. What proportion of roundup should I use per litre and will it affect the vegetables?
Using the standard 10ml of Roundup per litre of water you can kill the grass without harming your vegetables. I would spray only on a nice calm day and use a piece of cardboard to block any over spray from reaching your veggies. Roundup works through absorption by leaves so transfer by groundwater is not a concern. Also remember more is not better with Roundup, too much just kills the leaves before they can absorb the toxin and kill the root.
Mar 30, 2011 | Roundup "" Weed & Grass Killer
I need to know How much roundup per gallon of water. Also, can I mix Krovar with it and if so how much per gallon?
I use 3 oz. of Roundup to every gallon of water and it kills even the local star thistle. They can be used together with the Krovar ratio at 2.4 oz. per gallon.
Mar 27, 2011 | Roundup "" Weed & Grass Killer
I have used Roundup weed killer in the past, and am satisfied. But I no longer have the instructions about how much product to mix per gallon (or quart) of water. I use small amounts, like a quart sprayer....
I have a 5ltr can of Roundup and the dilution ratio for general week killing is 1 part Roundup to 4 parts water. I use this ratio all the time and it workes a treat.
Mar 10, 2011 | Garden
How much roundup concerntrated herbicide mm per litre to kill grasses and simple garden weeds
for roundup weed & grass killer concentrate plus you would use 3 oz per gallon or 29.57 cm^3 per litre
Dec 28, 2010 | Roundup "" Weed & Grass Killer
For general weeds what ratio round up to water do i use? thanks Jon
The recommended ratio is 50-1 or 2.8 ounces per gallon of water...
This gives a good kill in most cases...
heatman101
Sep 30, 2010 | Roundup "" Weed & Grass Killer
I've lost the page that tells me what ratio to mix my Roundup weed killer to water - can you please tell me?
Actually you can have different strentgh concentrates...but the normal strentgh is mixed 4 ounces per gallon.
heatman101
Aug 20, 2010 | Roundup "" Weed & Grass Killer
How much Roundup do you mix in one gallon of water?
If you have the concentrate (label reads Concentrate Plus), the amount of Roundup will depend on the plants you want to kill. Use 6 fl oz (12 tablespoons) for 1 gallon for most plants. If you have seedlings or easy to kill weeds, use 3 fl oz (6 tablespoons) per gallon.
The Super Concentrate may have a different rate. The labels are usually on the manufacturer's web site as PDFs.
I hope this helps.
Jul 05, 2010 | Roundup "" Weed & Grass Killer
Need to know how to mix round up and water
Annual and perennial weeds can be controlled with a mixture of 6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
May 27, 2010 | Roundup "" Weed & Grass Killer
Roundup "" Weed & Grass Killer Logo
9,264 people viewed this question
Top Roundup Garden Experts
Nick Olsen
Mike
Are you a Roundup Garden Expert? Answer questions, earn points and help others
