How to remove the float
Check the float to make sure it moves freely up and down, and it should click when it moves. Remove float and clean around the float tube-you may need to do this from below, through the access panel. Use white vinegar to scrub the float and shaft assembly. Turn on the dishwasher to see if this fixed the problem.
If not, it may be the float switch. If you are handy with electrical repairs, turn off the power to the dishwasher, pull the dishwasher from the wall and remove the back. Remove the wires from the terminals on the float switch-use masking tape to identify to identify terminals,noteing which belongs where.Remove old switch and replace with the new float switch. You will need the serial number, model number and make of your dishwasher to order the new float.
