As a general rule, the size and shape of the bulb will determine the wattage. Match it up with ones in the store, the value can be slightly higher or lower but it will still work just fine. Halogen bulbs burn out much quicker if you handle them without gloves or tissues. The oil from your fingers will cause them to burn out faster.
You may have this
posted in the wrong product category. Please select another category
appropriate to the problem and re-post the problem so the correct
expert will see and respond to the question..
This is for
car and truck problems related to Factory Installed Systems not
add on aftermarket systems.
This post
can't be removed or moved, please re-post the question in the correct
product category. Thanks
