Invicta 1003 diver watch
SOURCE: how to remove links on invicta russian diver watch
Hi Pate the only thing i can advice you is go to a service center near to your place.All watch technician like me have the knowledge to remove the links with no impaired damage or scratch.We know how to detach the links.So if want to know more of your watch i will give you a site that can help you and ask more information about your watch. www.invictawatch.com
SOURCE: i have an invicta corduba diver watch how do i
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
SOURCE: how do I change the date on my invicta divers
The answer to your specific question is the 2nd instruction below...I've also included two other settings:
Here are the 3 main crown positions
you need to know once you unscrew it from its locked down
position:
1) unscrewed, it can be manually wound, in one direction
[clockwise}...20 to 30 half-turns seems to be good to get it through
the night.
2) then, pulled out one small stop, the date can be advanced by turning the crown towards you (ie, counterclockwise)
3) pulled out one more stop, the time is adjusted by turning the crown.
I hope this helps!
SOURCE: how to shorten my invicta (mens pro diver 8932)
minutes.
