20 Most Recent
Invicta Pro Diver Collection Grand Diver Alarm #3443 Watch for Men Questions & Answers
How to set a invicta 3443 watch up
To set the time pull the crown out to the first position and set the time by turning the crown. Pull the crown out to the second position to set the date. Since this is a diver model you will need to unscrew the crown before it will pull out. Make sure you replace the crown and screw it back down for a good protective seal.
The alarm sets the same way. Unscrew the button to set.
Invicta Pro Diver 48mm 40239 Watch.
Question edited for spelling of maker.
Question moved from Computers.
Take it to a local jeweler store. The buttons need cleaning and servicing will fix it being off centre. Have a new battery are the same time.
How do I set the time on an Invicta Pro Diver watch?
Depending upon the movement, most pro divers have a *****-down crown for water tightness. First unscrew the *****-down crown. You can then pull the stem out one or two clicks. The first click permits you to set the date by turning the crown one way or the other. The second click should permit you to adjust the time. Then push the crown back in, hold it down and ***** it down 4 water resistance. Be gentle when manipulating the crown and stem!
How do you set an Invicta Pro Diver 12470 Watch?
Insulting answers. Respondents simply didn't RTFM, which is lame in all three dimensions - typically Invicta. This product has been out since 2011. Where is its pdf manual? ESPECIALLY this product, which is so different than most every other Invicta watch !!
