Adjust the carburetor screws in all the way...do not force them. back the screws out one and a quarter turns and the machine should try to start. adjust the screws one at a time... one quarter of a turn until the machine runs properly. Then adjust the idle.
With 2 strokes I always start with 'AIR' 'FUEL' 'SPARK' from the sounds of it the choke might be stuck on (choking the motor ha ha) also check the air filter, You have fuel and its moving through but the fuel filter might be slightly clogged. As its starting and going on low your spark unit is ok but you might need a new spark plug.
The first thing you need to do is take the recoil cover off. There are several parts to a recoil and one or more parts may be worn and coming out of place then jamming.Replace worn parts if this is the case. If the cord pulls freely when removed then you may have a problem in the engine, try turning the flywheel by hand with the spark plug out. If it does not rotate there is something inside the cylinder or broken in the crankcase. If it is a 4 stroke engine you may have fluid above the piston,you will find this out when you remove the spark plug. drain the fluid from the cylinder and replace the plug you will be good to go. Good luck
Battery is NO GOOD.... need new ones, these quickly go bad, if not religiously charged and discharged. You must charge a long time when first get them, and then as soon as flat must go back on charger, for at least 4hours... regardless what is said. If ever removed before properly charged, then it will "remain" at that level, next charge and so on... All batteries MUST be flat before recharge, and full before used again, no exceptions.
As with all 2 stroke engines,
1. Pump the fuel plug. 3 -5 times.
2. Turn the stop botton onto start.
3. Choke onto hot.
4. Pull the cord . Most important... dont touch the throttle trigger when pulling the cord. Wait until until it starts up.
If you do. (like it says in the instructions, your flooding the engine)
Works every time for me on everyone's whipper snippers.
I never heard it called a whipper snipper before but I am on this side of the ocean. you should be able to go to www.ryobiuk.com. Put in your model number and you should find a parts list for it. HTH Good Day. mate
