Maytag M7DH65B2A Dehumidifier Logo
A
Anonymous Posted on Jun 13, 2014
Will it shut off when you push power button - Maytag M7DH65B2A Dehumidifier
Logic dehumidifier has stopped working
Check the fuse in the power socket.
Look at the back and check if a red button is out, push it back in.
Bought the Frigidaire 6000 BTU Window Room Air Conditioner LRA067AT7 6 months ago and it worked fine until last week, It will not turn on although plugged in and the wall outlet is good. Is there an auto...
Good Morning Luca,
I understand your Frigidaire air conditioner, model# LRA067AT7, will not turn on. I also see that the wall outlet is good, so you are wondering if there is an automatic shut off if the filter has not been cleaned. Your air conditioner does not have an automatic shut off, if the filter has not been cleaned. Please start by cleaning the filter. You can do this easily with the following instructions:
The air filter should be checked at least once a month to see if cleaning is necessary. Trapped particles in the filter can build up and cause an accumulation of frost on the cooling coils.
    1)Push the vent handle to the Vent Closed position (where applicable).
    2)Open the front panel.
    3)Grasp the filter by the center and pull up and out.
    4)Wash the filter using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing
    5)Or instead of washing, you may vacuum the filter clean.
    Also, be sure your air conditioner is properly grounded. To minimize shock and fire hazards, proper grounding is important. The power cord is equipped with a three-prong grounding plug for protection against shock hazards. Your air conditioner must be used in a properly grounded wall receptacle. If the wall receptacle you intend to use is not adequately grounded or protected by a time delay fuse or circuit breaker, have a qualified electrician install the proper receptacle. Do not run your air conditioner without outside protective cover in place. This could result in mechanical damage within your air conditioner. Do not use an extension cord or an adapter plug.
    The power supply cord contains a current device that senses damage to the power cord. To test
    your power supply cord do the following:
      1)Plug in your Air Conditioner.
      2)The power supply cord will have TWO buttons on the plug head. Press the TEST button. You will notice a click as the RESET button pops out.
      3)Press the RESET button. Again you will notice a click as the button engages.
      4)The power supply cord is now supplying electricity to the unit. 4)
      I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
      -Best Regards-
      WP
2answers
LG LD450EAL no power
Try resetting the GFI breaker, assuming it is connected to one. Also check the main breaker panel to make sure the breaker is not tripped. Unfortunately the electronic panels do go bad in these systems after a few years of service. Try resetting the unit. There should be a tiny reset button on the back. Also if the bucket is full it will not turn on, make sure it is in place and seated properly or it will not turn on. There may be a reset on the cord itself as well, hope this helps.
Hello, I have a Whirlpool dehumidifier Model# AD25USV (recall adjustment already complete) I have never had any technical problems or damages to the unit, and it has worked great, until...
Hello Shane
Mine won't beep at all. But try this trick I watched the guy do when he came to service mine for the recall they had and push Humid button fan button and power button first hold the first two then push the power button and hold all three for awhile. What this did for him was verify all systems working all the lights came one in sequence.
I do this to mine and will beep twice and nothing else. I've taken mine apart to check the fuse and it's still good so there must be a component that is not working.
On the back of your unit you will find a 800 number which will get you in touch with Trans Global Service which serviced it for the recall.
George
1helpful
Auto shut off comes on instantly
TURN UNIT OFF.. MAKE SURE DEHUMIDIFIER HAS NOT BEEN RUN FOR AT LEAST FIFTEEN MINUTES... TAKE BUCKET OUT... HOLD IN THE BUTTON THAT THE FLOAT IN THE BUCKET PUSHES ON.. THEN TURN ON THE UNIT.. DO NOT LET GO OF THE BUTTON EVEN A LITTLE BIT IF YOU DO YOU WILL HAVE TO WAIT FIFTEEN MINUTES AND TRY AGAIN.. IF UNIT WORKS THEN YOUR FLOAT IN THE BUCKET IS THE PROBLEM...
The dehumidifier runs but no waster is coming out
Frank it sounds like to me that it needs to be shut off a while, Was there a power outage or did you happen to shut it off and try to restart it real fast. If so then the compressor can not push the freon through. let it sit for about 8 to 10 minutes so the pressure drops and then restart it. Otherwise it will just burn up the compressor
1helpful
01% humidity
When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
The compressor is located in the rear bottom on the right side looking at the machine. After you press the start button and the blower fan comes on, bend over near the back of the unit and listen for the "click".
KENMORE 70 PINT DEHUMIDIFIER
4681A20040R is the fan part #. Bought one on e-bay. Fixed the same problem.
Top Maytag Dehumidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
