In general, normal electricity is supplied by utility companies. When the main power supply stops, we can switch the 60KVA diesel generator set manually or automatically to the field application. The main task of the switching switch is to switch the power from the power grid to the backup power supply. The diesel generator manufacturer will explain how to operate the automatic switch through the control panel.
A switching switch control panel system makes the unit more automatic. Manual switching switches are operated and used by field personnel when backup power needs to be immediately restored. An automatic switching switch, can immediately detect power failure, can make the generator work automatically. The job of the control panel is to detect power outages and start programs to start new or old generators. Once the new or old generator reaches the correct voltage and frequency, the switch that controls the system signal shifts from the usual power to the generator. Although the principle of automatic switch is very complicated, it plays an important role in the automatic operation of generator. https://www.dieselgeneratortech.com/cummins/cummins-82gf.html
Is the auto transfer switch rated to handle a 60 kva gen set cus you can use a larger auto switch on a smaller gen set but it don't work the other way cus you'll be burning up wires and contactors and have a fire !
