Northstar Pressure Washer 3000 PSI Logo
A
Anonymous Posted on May 20, 2014
Why rac 2000 power wash not pumping - Northstar Pressure Washer 3000 PSI
2006 Dodge 1500 5.7 hemi-Changed the power steering pump. 1,500 miles later the steering is very hard at low speeds. Is there air in the system, bad pump, or maybe rac & pin issue?
Indicates the pump not producing enough,in park rev the engine to say 1200 rpm and see if it acts the same as 20mph turn steering at same time.
1500 hemi 5.7 Changed power steering pump. About 1,500 miles later the steering is very hard at low speeds. Is there air in the system, bad pump, or maybe rac & pin issue?
Jack the truck up and see if it's hard to turn . Now if you did nor flush power steering system the pump could have gone bad . Most power steering pumps carry a warranty on them wouldn't hurt to swap it out he can do the work yourself but it sounds like your rack and pinion is starting to fail
1helpful
2answers
HOW DO I GET A MANUAL FOR RAC 515F SAT NAV
ROUTE 66 - RAC satellite navigation devices
tw2.ro.66.com/rac/index.php?cid=UK
RAC Sat Nav 515F ... If your RAC Sat Nav develops a fault in the first instance contact the RAC Sat Nav ... If you have any questions about using your RAC Sat Nav please call on 01302 ... ROUTE 66 Navigate 7 - User manual - SW (499KB). ROUTE 66 RAC satellite navigation devices
It offers a PDF to download or read online.
Dec 10, 2014 • GPS
What would cause hard steering when the power steering isent gone
bad pump, bad tie
rod ends, bad balljoints ,bad rac and pinon!!!!!!!
I have a 2.0 dti vectra 02 reg just will not start the man from the RAC put some easy start in it and it ran for abuot 2sec then stoped
That was a sign you need a fuel pump.. What a tech will do is check to make sure you have power and ground at the fuel pump., if you do and you have no fuel pressure then the pump is bad. If you dont then he will have to figure out why the pump is not receiving
5helpful
Do you know where or if a 2000 Mazda 626 has a fuel pump cut off switch. According to the parts store it doesn't have a fuel pump relay. I have replaced the fuel pump and the car still won't crank. I am...
Hello, I am going to make a few assumptions here. The vehicle has an electric fuel pump and you replaced it. The vehicle has fuel injection. The engine is actually cranking, just not starting, when you say "car still won't crank". You are getting fire to the spark plugs at the plug ends. You checked the fuel pump for power at the pump. No power, then you back traced the wire to the fuse block and checked the fuse to see if it was blown. If the fuse is good back trace the power to the ignition switch and/or ECM for power. You have power at the pump, check the ground and make sure it is connected properly. Will the pump run when someone turns the key on? Pump runs, check fuel manifold for pressure. No pressure, check the fuel filter for blockage, or replace it. Fuel pump doesn't run, new replacement pump is defective. There is usually some type of control module for the fuel pump on fuel injected vehicles. Good Luck, RAC
Have got an hyundai sonata 2000,i parked to drop a friend and
look at the starter relay and fuses and power coning aut of the ignishion
Top Northstar Garden Experts
Mike Cairns
Mike Cairns
CJ Rock
CJ Rock
Are you a Northstar Garden Expert? Answer questions, earn points and help others
