SOURCE: I have a Husqvarna lawn tractor 48
When your tractor is running check the voltage at the battery posts with a meter. If the voltae is above 12 you are chrging good and need to replace the battery. If it is lower than 12 then the regulator and altinator are next. Remove the regulator and you will find numbers on it to take to a dealer and replace or have checked. Do the same with altinator..it could be either so give it your best guess in the order you want to have them checked. On a personal note..check your ground wire from battery to frame and make sure it is tight and clean. :) Hope this helps.
Testimonial: "This give me a place to start. Thanks!"
SOURCE: I NEED LOCATION OF SERIAL NUMBER ON HUSQVARNA
Thanks a ton ******. Seriously. I'm already agrivated because they have the dam year model in secret code and then some ******** tells me to look under the hood. Like we all have not checked the whole mower for a sticker showing the year model before wasting time asking people who are more clueless than us.."... Lol,,,, mines under the hood........ Wow. I'm done.
SOURCE: Husqvarna riding mower, (Model: YTH2448) won't turn over
turn on device and wait for response inspect every component for malfunction
