My phone is a Motorola XT555C. After I press "add new", it goes straight to "android.process.acore" then "has stopped unexpectedly, please try again", then closes out the whole program. I've tried deleting any excess or duplicate entries, but so far nothing seems to change that behavior. Don't know what to do -if I can't even add any new entries! [KITTY]
SOURCE: how do i get rid of error message "the application
It happens when the process is manfuctioned or corrupted. I advise to do a factory reset. To do so, turn off the phone, holdon the home button and press the power button. It will go to recovery console, now select "Wipe to factory setting", once finished, turn off the phone and restart. It should take care of the issue.
Thanks and regards,
Anil.B.R
SOURCE: My motorola flipout phone. Upon opening, the phone
Goto
Settings > applications > Manage Applications > Home > Clear
Data.
If this does not help , then Perhaps you have too many background apps open thats making
it crash?
I would suggest going to the market place and finding
"TasKiller" it eliminates any and all apps that may be taking up memory
from working in the background. It comes with a widget you can add to
the homescreen for one touch elimination. after it clears everything
your screen will be black and then might go to call log screen. Just hit
the home button and everything will run like normal but it will be much
lighter on the memory.
SOURCE: i get a force close message on my phone. what do i
This basically means the OS is having severe problems. You need to try a master reset first. If this does not work and there is no software update available from the HTC website you need a replacement handset.
