all oil tanks on chain saws take Bar/chain oil this can be bought same place u buy 2 cycle engine oil most times , this bar chain oil most times is a 30W oil , if you change weights of oil then oil pump is not gonna add proper amount of oil to saw in use ,this will cause u problems !
Your chain saw is a manually oiled model which means YOU have to pump
it.YOU do not pour oil on the chain. An auto oiler model works without you doing anything, the pump is run by
the engine. A manual model, you pump the oiler The Chain saw has internal oil channels or holes to apply the oil directly under the chain and into the chain bar guide. Pouring oil on the guide or chain will NEVER lubricate the chain properly. Whomever gave you such an idea is just plain wrong. I sent
you the link to the owner manual and gave you a diagram. Click here
most any bar and chain oil for chain saws will work. The cheaper the better just make sure you keep the chain oiled up. if you can touch the chain and oil oil does'nt get on you you not using enoght and put oil right on the chain. certainly when you put the saw away to store it. even wrapping the bar and chain in a rag with oil in it is a good idea as it'll be ready for next time.
Without knowing what saw you have it is hard to exact directions.On most saws their is an adjusting screw on the bottom side of saw by oil tank and chain that adjusted the flow rate of oil. If you can locate that try rurning it one turn clockwise and run saw for a short period and see if you are getting any more oil.If youare sure you have the right screw I would continue adjusting . If it doesn''t seem to work I would remove screw and make sure there is no blockage and that oil is present. For proper operation you need to keep a light film of oil on it. If you aren't getting enough oil you will cause chains to overheat,possibly ruining chain and bar. Hope this help you. Thanks
If you take the bar off, and then run the saw, does oil come out of the saw? If it does, then the oil pump is likely working O.K.
If the oil comes out of the saw and does not make it onto the chain, it is possible that the oil exit slot on the saw, and the hole on the bar are not lining up properly. This happened on my Husqvarna 141 saw. The oil was coming out of the saw fine, but it never made it to the bar and chain. As a consequence the chain was always dry and very, very hot.
The other saws we use, always have plenty of oil on the chain. I think Husqvarna may have made a design flaw on some of their saws, and the exit point of the saw and the entry to the bar are not properly aligned. I wonder how many saws this affects.
I assume you are asking about the oil for the chain. Any good quality "Bar and Chain Oil" will do fine. Do not use motor oil you use in your car engine as it will not properly lube the chain and will result in quicker dulling and early demise of the chain.
You can get the "Bar and Chain Oil" at most hardware stores or Farm Supply stores.
Hi It would be helpful to know where durban is. In most parts of America "Bar Oil" is available at many hardware stores, and certainly at any chain saw dealership. Oddly enough, many "Green" aware saw operators are now using vegetable oil as a lubricant. So Canola oil, Corn oil, or any other fairly thick, heavy vegetable oil will work fine. The oil is pumped onto the bar at the top of where it exits the motor housing, and then circulates around the bar. Much of it is lost on the first pass the chain makes through the wood. This is carried away in the chip stream coming out of the cut. On many gas saws, you can see oil being slung off the chain when you rev the motor up. The green feeling is, all this oil is left where we cut. Are we leaving a biodegradable oil behind? Or a contaminant that will take years to degrade.
See also: http://www.fs.fed.us/eng/pubs/html/98511316/98511316.html
Stay safe, keep the blade sharp - use the protective gear as directed. HF
The oil to use for the chain is called BAR OIL and if there is anything that might be universal, it is BAR OIL. You can use BAR OIL on electric and non electric saws alike. Self sharpening and non-self shaprening chains. Any manufacturer. It is BAR OIL.
Do not use any other kind of oil in your saw. BAR OIL is particularly sticky and hangs on to the chain even while cutting the wood at high speed.
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
