Have you a system board with Pentium 4, one slot isa, one slot agp and sata I/o? I want to know what is the PN of theses system board?
SOURCE: I have a PCCHIPS M810DLU
use the built in graphics adapter to start up then when in windows right click on my computer then click on the hardware tab . then clck device manager .. then double clck display adapters .. then double click on the display adapter that is built in.. and then in its properties window select disable/do not use this device.
SOURCE: Can a R9550 Sapphire graphics card fit to optiplex 170L
It is possible you can etheir find an agp of the appropriate generation for your video card and attempt to solder it into the board. Even then you will need to re-program the bios to recognize it. Would be very difficult to do though as you would need to know how to code the eprom in machine language.
SOURCE: mercury n1996.......AGP slot or PCI????
n1996 is NOT the model number. ALL MSI boards are labeled n1996 - it's their C-Tick number. You need to find the actual model number which should be listed on a sticker near the main CPU socket. Search for that on msi's website.
Let me know what the model # is..
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Mobo Jumper settings for BX pro PC100 Motherboard
*********** board sounds like the same as a Fujitsu board.
D1115
the user manual can be found at diplodocs
It shows the jumper settings and board layout for a Fujitsu motherboard.
I hope this helps. Have a great day
SOURCE: my dell gx 270 p4 sata pc is containing pci slot
It is containing PCI slot for graphic card.
