SOURCE: Lenovo 3000 Y410 Wifi Problem
If this is the case, reboot the machine and then see if the wireless works.
SOURCE: White Screen for Lenovo Y410
can you try and power up in safemode
by continuosly pressing f8 during startup
see if you can get in safemode
SOURCE: Lenovo Y410 Touchpad has stopped working
These devices are generally quite reliable so I would be looking for the possibililty of a damaged software driver.
If the touchpad is completely dead, use the tab and arrow keys to access the Control Panel.
Open the Mouse folder, go to the Hardware tab, locate the touchpad entry (it is likely shown as a mouse), highlight it and delete the entry.
Exit the open windows, reboot your computer.
If the touch pad is functional at all, Windows should show a dialog box stating 'Found new hardware' and it may also say that it is installing the software for it.
It may however, ask you to insert a disk with the software on it and that would be on any recovery disk that came with your notebook.
If it does not see the touchpad because it is defective, then it is a failure of the touchpad.
Good luck-
SOURCE: Wifi driver of Lenovo Y410
Here is the link for Intel....you will need to know the model #
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17227
and here is the link for vista drivers at Lenovo
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_list.aspx?CategoryID=6
I hope this helped...if so please rate me ...thanks ..The Fang
