Whick processor will support this motherboard processor p4 pga 2.40 GHz already used not working
The p/n (FRU 49P1599) is a Gigabyte motherboard, their p/n GA-G8IGMIU Rev 1.1 It seems to be a socket 478 type with FSB 400 or 533MHz, Intel 845G chipset, and DDR1 memory. In the downloads section of Gigabyte's website it is not present, probably because it so old it has been removed. In this section there is the opportunity to get the manual for a motherboard and the CPU support list, amongst other downloads. A similar m/b, the G8IG model supports ONLY older Williamette and Northwood type P4 CPUs, not the (slightly) newer Prescott ones. I suspect that your CPU is not working because it is a Prescott type (or it is just broken). To check what process your CPU was made by use the program Speccy, or take a magnifying glass and examine your processor (having carefully cleaned it up) for the S-code, RK or BK number, and look it up on Intel website (ARK) or in CPU-World.
AND you should contact Gigabyte technical support (you have to go through the register rigmarole) to see they are able to answer questions you may have, get the manual and the CPU support list.
9.April.2014
SOURCE: 845GVSR MotherBoard problem
actually the problem is that it is xp sp-2 is not compatibilty with ur motherboard driver it occur due to when autoplay function is not enable
SOURCE: I am looking for a motherboard manual for an IBM Board
hi
this is the manual for the system that this board is from
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/netvista_pdf/24p2969.pdf
I hope this helps
NetVista types 8181, 8182, 8301, 8303, 8304, 8305, 8306, 8307, 8308, 8309, 8310, 8311, 8312, 8313, 8314, 8315
in models
21U 21F 22U 31U 31F 31G 32U CTO 23G 11G 51U 51F 51G 52U 52S 52P 53U 53S 53P 61U 61F 41U 41F 54U 54F 54S 54P 81U 81S 81P E1U E1F E1S E1P 41G
SOURCE: Intel P4 2.66 ghz processor Intel MOtherboard D945
it might be that power unit give big currency to the mother board therefore it overheats.
SOURCE: Intel D845PESVL compatible processor
Here is a link to the INTEL Spec sheet
Testimonial: "Thank You, Dennis. Exactly the information I was looking for."
