When I pull the PTO swith, nothing happens.
SOURCE: When I engage the PTO, the blades don't egage.
The first thing we need to to do is verify that there is adequate /(power 12 vdc) going to the electric clutch, you can do this by unplugging the clutch and check both wires 1 should have 12 volts and the other wire shoud read infinity to ground if this checks out replace the clutch, if you dont have 12vdc to the wire replace the relay
SOURCE: my pto want work on my troy bilt 50' zero turn
Click the link below :----http://wikisolutions.blogspot.in/2012/02/get-free-answers.html
SOURCE: white z-200 pto switch wont engage mower blades, sputters and shuts motor off.
Electric clutch is going bad and mower doesn't have enough power to run the clutch. Clutch is running tight new clutch is around 270.00 dollars
