Only if you have it turned to Convection oven. Or it is a convection oven and then in that case the fan must always turn to circulate the hot air, do not use if fan is not turning .
For all Free appliance repair videos visit our VIDEO
TUTORIALS 1, If the Bosch fan motorin the back of the oven is going round and
the temperature light is on (normally little red light), but there is no heat
then you will probably need a new oven element, these are generally very easy
to fit and readily available from our website these can be tested with a
electric meter. To gain access to the BOSCHelement you will
have to remove the back plate from inside the oven. Once removed you will see
the fan and element, if you
look closely at the elementyou will
probably see a small hole burnt in it where it has blown. Sometimes however
there is no evidence of a fault but the elementis open circuit ie:
broken inside the element casing, either way it will need replacing. Some
elements will are fixed from inside the oven and some are held in place by nuts
from the rear of the machine. 2, If your BOSCH fan
oven is getting warm but takes a very long time to cook or is burning the food
more on one side than the other, then you need to check if your oven fan motoris working you will
see the blade turning fast if it is ok. if the element is heating but the fan motoris not blowing the heat into the oven then
you need To replace the oven fan motoris a little more
expensive and a bit more involved. 3. If you have the opposite problem ie: your oven is over heating
and burning everything then you will need to replace your BOSCH oven thermostat 4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no
heat and no fan then the chances are that someone has put the oven timerinto AUTO mode,
simply put oven back to MANUAL mode and all should be working again.
1 . If yourELECTROLUXfan oven is getting
warm but takes a very long time to cook or is burning thefood more on
one side than the other, then you need to check if your ovenfan motorisworking you will see the blade turning fast if it is ok.
if the element isheating but thefan motoris notblowing the heat into the oven then you need To
replace the ovenfan motoris alittle more expensive and a bit more involved. 2 . If you have the opposite problem i.e. your ovenis
over heating and burning everything then you will need to replace yourELECTROLUXoventhermostat 3. A quite common and easily overlooked answer isif yourELECTROLUX
oven is not working at all i.e. noheat and no fan then the chances are
that someone has put the oventimerinto AUTOmode, simply put oven back to MANUAL mode and all
These will give you the basics 1How
to change a fan oven element and How to change a cooker oven fan Motor 2How
to fit a New Thermostat to a Cooker or Oven
If you
have a electric Cooker or Fan
Oven which is not heating it could be one of the following problems. 3. If you have the opposite problem i.e. your oven
is over heating and burning everything then you will need to replace your oventhermostat
TUTORIALS
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
1, If the fan motorin the back of the oven is going round and
electric meter. To gain access to the NEFFelement you will
from the rear of the machine. 2, If your NEFF fan
and burning everything then you will need to replace your NEFF oven thermostat 4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no
