Panasonic (TH-50PZ700U) Television Logo
Anonymous Posted on Jun 11, 2009
No picture and the led ligth is blinking panasonic veita 52
Richard Foster
Level 2:
New Friend:
  • Expert 88 Answers
  • Posted on Jun 21, 2009
Richard Foster
Expert
Level 2:
New Friend:
Answers
88
Questions
Helped
39790
Points
214
If you have the flashing red light of death you can use the chart below, and call Panasonic to have it replaced. At the bottom is the list terms.
BLINKS PROBLEM MALFUNCTIONING PART
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Panel = Plasma Display Panel (Plasma Glass)
D Board = Format Converter / Plasma AL / Sub-Field Processor
DG Board = AC-DC Converter / Digital Signal Processor / Full HD
Microcumputer HDMI Interface / Peaks Lite 2
H Board = Speaker Out / Sound Processor
AV Terminal / AV Switch
P Board = Power Supply
PB Board = Fan Control
SC Board = Scan Drive
SD Board = Scan Out (Lower)
SS Board = Sustain Drive
SU Board = Scan Out (Upper)
Anonymous
Level 2:
  • Expert 187 Answers
  • Posted on Jun 11, 2009
Anonymous
Expert
Level 2:
Answers
187
Questions
Helped
99206
Points
459
Replace the mainboard.
My tv don't ligth but isow the red ligth at the corner which ligthing and ligthing again.What can i do?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty./
I have a panasonic th-46pz850u tv that its not turning on i have unplugged it for over an hour to reset it and all i get is a blinking red power ligth.please any suggestions.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
I have picture but no sound IN BULGARIA
If there is sound, and no picture, the front LED might be blinking for a certain fixed numbers at one time. Count these numbers. The number is more important because it is fault indication, called LED blinking codes. Check this link for more details about Panasonic blinking codes.
Green ligth com for a few second rex ligth blink for 13 time
Download its service manual. It will have all details to this fault.
Panasonic power led blinks but no picture
The model indicated is a rear projection crt (picture tube type) set.
Count the number of blinks and if you have to: uplug the set and try to turn it on again---most will blink a error code and the most popular are a series of 3 blinks, a pause and 3 more blinks etc.
Let me know the number of blinks and I will attempt to point you to what is wrong.
SD TECH
No picture
This set is a projection tv with 3 tubes red,green,blue more then likely 1200pf 2kvolt capacitor,hori output transistor.
TV Won't Come On...
My Hitachi Model 50V500 led's ligths temperature and lamp blink when power is turn on.Have no picture or sound, followed the reconmended procedure disconnected power
for 30 seconds and reconnected.
Panasonic 53wx42, no power, Blinking LED
Have you gotten any solutions to this problem? We had the same thing happen to our TV recently. Haha, maybe they all died on the same day. Before this, we had a convergence problem with the blue color. If you had it fixed, how much did it cost? Our warranty just expired too! Thanks
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
