LG Shine KE970 Cellular Phone Logo
Posted on Jun 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Broken my lcd screen end i need instractions for
Broken my lcd screen end i need instractions for open my phone end fixed the new lcd screen
Anonymous
Level 2:
New Friend:
  • Expert 113 Answers
  • Posted on Jun 07, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
113
Questions
0
Helped
38751
Points
360
It will be better not to open the handset yourself. Open the handset if you are a perfect hardware engineer. Otherwise some other problems could also arise.
Take the handset to the nearest LG service centre or an Expert Technician in the open market. Have them fixed it for you at a nominal cost.
3answers
Broken screen
Um... so... what's broken about it? The video didn't really tell me much.
May 27, 2013 • Cell Phones
1helpful
The internal screen on my LG Env Touch remains blank after opening. The interenal keypad lights up when opened, but not the screen. The phone did not get wet, to my knowledge, and was functioning properly...
Hi, most screen problems usually happen after a fall or a knock against a solid object. There are two things that might have happened here. One might be, the screen got a hairline crack and the connection to the lcd is broken. The other is that the lcd did not crack, but the connector flex cable is disconnected. The first requires a replacement lcd. The second requires an inspection to see if the flex is disconnected or broken. (You will have to open the phone). If you cannot DIY, then take it to a repair shop. Replacement lcd can be found on ebay.
2answers
Hello, I would like to fix my Samsung Strive phone screen myself. Can you help me? The screen is broken but not cracked. It has a spider/star shaped blotch that covers about half of the screen.
Hi barbaradwall,
Actually the spider web blotch that you can see on your screen is an indication of a cracked LCD. The only way that you can fix this is to have the LCD replaced by an authorized technician since special tools will be needed to open your phone and fit a new LCD.
Hope this helps.
Thank you for using FixYa.
2answers
Fixed lcd screen and has broken again
Take it back to where you had it fixed, get it fixed again and be careful with it.
3answers
Samsung SCH-u740 broken inside LCD
hi! you want to change new lcd screen only!
Thanking you............
3answers
Broken screen
I have the same problem......I NEED HELP!
1helpful
Sidekick 3 problems
Antonio-
You may be able to fix many of those things yourself. The trackball proabaly just needs to be clean. Does the LCD have a white screen when it is on? The Camera, well that may take some work.
For the white screen check out here: http://www.repairmysidekick.org/Fix-Sidekick-White-LCD-Screen
If it is not white, a new lcd can be had for 45 dollars on ebay.
they are easy to replace.
replacement of the Sidekick 3 LCD flip screen.
To clean your track ball, follow these instructions:
1: Take a deep breath and blow on the trackball area, rotate and do it again. This may blow any particles block the sensors.
2: This requires a Q-tip and some alcohol. Turn off your sidekick, wet the end of the q-tip, and gently clean the trackball while rotating. Be careful not to get the alcohol on anything but the trackball. Let dry for a minute and try it out. If this doesn’t work then try again.
2answers
Broken screen
boatsy,
replace the lcd..
My LG CU500 LCD screen is broken
My LG CU500 LCD screen is broken what do I do
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
