First I thought it wasd just just the power steering pump because it had plenty of fluid, and it would make a loud screech while turning, but today while driving gears 2, 4, and Reverse wont engage. Gears 1, 3, 5 (luckily) work just fine. It is a fairly new engine/transmission/clutch... HELP
Are you saying this car is a A/T car, AUTO and not a stick?
say so, as both have 2,4 and reverse gears.
i think its a 5speed manual.
so the tip of the shifter is bad, remove it see plastic parts bad.
you could shift car , by moving the transmission levers and id bet it does work so that leaves. bad shift lever parts.
i bet the lever is real loose , so loose the H pattern is garbage
right> ?
SOURCE: My bottom gears won't work in my 1991 Toyota Celica ST 5 speed
sounds like synchronizer ring assbly
shack
SOURCE: 95 4runner engine just revs tranny won't go into gear or reverse.
on this model not have solenoid for reverse gear, and when the torque converter is burn this cause loose of fluid by dip
SOURCE: vault on automatic gear box on toyota estima enima
2.2td estima enima,the auto gearbox stopt change gear from 3 to 4,can somebody help me please?
SOURCE: my 94 toyota corolla wont go in to gear, but will go in reverse and when i do that it grinds.
Check the linkage, probably worn out
