Always be sure the battery is charged and suited for your camera.
Check contacts of the battery and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the battery before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
If you have a multi meter, you can check your battery. After charging the voltage should be higher (few tenths of a volt) than the voltage printed on the battery.
If the voltage is slightly lower, you know thee will be not enough left when the battery needs to deliver some power.
SOURCE: Sony DSC-W80 message for use with compatible battery only
please remove the battery while pressing and holding the power button for 1 min. plase make sure that the battery supplied for yer camera is an NPBG1 original sony battery.
SOURCE: e:62:12 keeps flashing on my camera
We had the same problem, Sony DSC W80 with the code E 62:12 flashing on the upper right side of the LCD screen. The camera was rotating the photos by 90-degrees. After reading that E 62 was related to the steady shot function, I figured it may be a stuck potentiometer in the camera (it has little sensors that tell the camera what it's orientation is, I guessed one of them was stuck from a "light" fall earlier in the day, while the camera was in the case). I firmly banged the camera in the palm of my hand 3 times on 2 sides... The problem's gone and the pictures are no longer rotating.
SOURCE: compatability?
I set the USB to PictBridge mode (press home button, then main settings). Now iPhoto recognizes the camera and I can import photos.
SOURCE: Sony Super Steadyshot DSC W80 and lens keeps going in and out
Hi, Focal lens out of sync. camera cannot initialise. Lens requires manually resetting. If you in the U.K , I can help you out.
p.m me at [email protected]
SOURCE: I have a sony dsc-w80 that won't turn on. I
you have a bad power switch, you will need to take the camera apart and clean the inside of the switch with alcohol
