My 1994 Chevy Suburban's taillights and brake lights do not light up, but the 3rd bight brake light does work. Also when the turn signals are used the signals in side the care blink very fast and the ones on the outside rear do not work at all.What is preventing all of these lights from working all at once?
I would start at the rear sockets. If they are fine and in good shape. The next thing to check is the blinker switch. The blinker switch and hazard switch may have a blown fuse.
Ck fuse for rear taillights tis under the dash lower left of steering wheel. or if you still have the manual look in there under fuses.
also look for a bad ground but i doubt that.. if it's both rear out.
fast flashing well here's a chart with all sorts of info.
Problem What To Do
Turn signals light, but do not flash Replace the flasher
No turn signals light on either side Check the fuse. Replace if defective.
Check the flasher by substitution.
Check for open circuit, short circuit or poor ground.
Both turn signals on one side don't work Check for bad bulbs.
Check for bad ground In both housings.
One turn signal light on one side doesn't work Check and/or replace bulb.
Check for corrosion in socket. Clean contacts.
Check for poor ground at socket.
Turn signal flashes too fast or too slow Check any bulb on the side flashing too fast. A heavy-duty bulb is probably installed In place of a regular bulb
Check the bulb flashing too slow. A standard bulb was probably installed in place of a heavy-duty bulb
Check for loose connections or corrosion at the bulb socket
Indicator lights don't work in either direction Check If the turn signals are working
Check the dash indicator lights
One Indicator light doesn't light On systems with 1 dash indicator:
- See if the lights work on the same side. Often the filaments have been reversed In systems combining stoplights with taillights and turn signals
- Check the flasher by substitution On systems with 2 Indicators:
- Check the bulbs on the same side
- Check the indicator light bulb
hope this helps. may want to print for future reference. :)
hope this helps.
SOURCE: having trouble with brake lights and turn signals
could be a few reasons...first check trailer wireing harrness..if none or ok then replace the curcit board in the tail lights
SOURCE: no turn signals or side brake lights on 94 chevy suburban
or it could be the body control module is bad it is commonly known to go bad and all of the vehicles lighting is run through the body control module
