Has a black screen !?! Even when I hold the power button down for 6-20 secs the screen still stays black when powered back on !?!
SOURCE: black screen at power on
I had the same problem. I pull of battery and then immediately reattached and ta-daaaa! Windows came right up!
Hope this helps!
gg
SOURCE: Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
SOURCE: While playing a game, my
If holding down the power button for 10 seconds (theoretically, try holding it down for ages and be patient) doesn't reset your device, you may have to wait for the battery to run flat, then try the reset procedure again.
Hope this helps,
Alistair
SOURCE: tablet wont power on. Holding
do one thing Turn Off Your Tablet
-> Hold Volume Button and Power button for 3 to 5 Secs -> You will see a screen with android and triangle with exclamation mark -> you will also see 4 lines of writing in blue. -> use volume buttons to navigate to 3rd option, use home to select it ( warning this will erase your system data if need please take backup) (memory card is not affected) -> now navigate to 1st option saying " reboot to system" use home key to select it.
I hope this will fix things
NOTE: This will erase everything from the tablet and reinstall its operating system to factory default. This is the only way to get passed the password if you forgot it.
1). Make sure the tablet is off.
2). Press the and hold the POWER BUTTON the obediently press and hold the BACK BUTTON.
3). Continue holding BOTH buttons until the Emetic logo appears. The release only the POWER BUTTON continue to hold the BACK BUTTON until the android with open door and menu appears.
4). Select "WIPE DATA/FACTORY RESET"
5). A list of several "NO.." will appear, scowl down and click on the only "YES.."
6). With the "Yes.." Highlighted in a blue bar press the "POWER BUTTON" one time.
7). The system will format and restore the operating system.
8). Select "REBOOT SYSTEM".
9). You should be good to go.
9). You should be good to go!
