SOURCE: forward/reverse lever not holding in position on
Some come with a tension bushing underneath on linkage. Check that first
SOURCE: john deere 300 garden tractor will not go forward or backwards
Make sure the neutral lever (rod) back by the right rear tire is pushed ALL the way in.
SOURCE: my john deere 316 stopped moving forward and
HAVE YOU CHECKED THE TRANSMISSION/HYDRAULIC
OIL? THEY ARE THE SAME. ON SOME TRACTORS THIS
CAN BE CHECKED AT THE REAR OF THE TRACTOR JUST
BELOW THE SEAT. IT COULD ALSO BE A BAD HYDRAULIC
PUMP.
SOURCE: My John Deere traveling sprinkler
Improperassembly. Change the direction of the nozzles on the spray bar so it turns in the opposite direction..
SOURCE: I have a John Deere
Your model has a hydraulic cylinder attached to the pedal linkage and its purpose is to slow the pedal movement when depressed. When this little shock/cylinder fails the pedals move to quickly giving you the sensation of rear wheels locking up. Its between the frame and trans on the right.
