Heating & Cooling Logo
A
Anonymous Posted on Jan 12, 2014
Won't stay running - Master Heaters Heating & Cooling
Car won't stay running
If the problem only happens when the engine is cold, a bad electric sensor is likely to blame. If the car stalls even when the engine is warm, the cause is likely a faulty electric fuel pump.
Why is it that my car starts but won't stay running? ' Reference.com
https://www.reference.com/vehicles/car-starts-won-t-stay-running-6449388a9326285d Car won stay running Google Search
Starts but won't stay running
Did you changed fuel filter.
1helpful
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
98 Expedition..5.4L 4WD..coded bank 1 bank 2....O2 sensors..LEAN....replaced both..no change..still same codes..now it won't stay running. Tried to code again..won't run long enough to get a c
all code readers will retrieve information stored while in the on position --doesnt need to be running ---when you rehook up scanner either resubmit or edit request with codes
It will crank but won't stay running
installed new fuel pump and filter in 97 cavalier 2.2 the car will run for a couple seconds and shut off if you spary it with starting fluid it will stay running
My on off button won't stay pressed down so the vacuum won't stay running.
Hi Melissa,
I'm sorry to hear you're having difficulties with your DC17. If the on/off switch doesn't seem to be working correctly, it's best if you get in touch with us directly so we can help. You can call us free on 1866MYDYSON, or email [email protected]. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Won,t stay running
maby the timing is of or fuel injectors even spark plugs or cables
Won`t crank
check your fuel pressure and also check your plug gaps and make sure you have a stong spark, you say it stays running once started on ether? does it run well or poorly? is it drivable or not please explain in more detail -please rate -jeff
Top Master Heaters Heating & Cooling Experts
Paul Carew
Jesse Walters
Jesse Walters
David Spradling
David Spradling
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
