receiving670: You must load a program to execute it. You can make your program using JobGenerator, or i can help you to develope it. Roberto Martinez [email protected]
The HT630 scanner is a handheld barcode scanner, and an error message can occur for a number of reasons. Here are a few steps you can try to clear the error message on your scanner:
Check the user manual: The user manual for the scanner should have a list of error messages and the corresponding solutions. Look for the error message that you are seeing and follow the instructions provided to clear it.
Restart the scanner: Sometimes, simply restarting the scanner can clear an error message. To do this, turn off the scanner and then turn it back on again.
Check the connections: Make sure that the scanner is properly connected to the host device, such as a computer or a mobile device. Check the cable connections and ensure that they are securely connected.
Check the battery: Make sure that the scanner has enough battery power. If the battery is low, the scanner may display an error message. Charge the scanner or replace the battery if necessary.
Update the scanner firmware: Make sure that the scanner's firmware is up to date. Outdated firmware can cause errors and malfunctions. Contact the manufacturer for instructions on how to update the firmware.
Factory reset: If none of the above steps work, you can try performing a factory reset on the scanner. This will erase all the configurations and settings and will set the device to its original state. Check the user manual or contact the manufacturer for instructions on how to perform a factory reset.
If the error message persists after trying these steps, it's recommended to contact the manufacturer or a professional technician for further assistance.
It's worth to mention that, Each scanner has a specific error code, some error codes can only be cleared by the manufacturer, by sending the scanner to repair or by a firmware update.
ncarovic: This is not an error, this message indicate that not exist any program to run. You must load a program to execute it. You can make your program using JobGenerator, or i can help you to develope it. Roberto Martinez [email protected]
This handheld can be programmed to capture data, perform verifications, inventory, store entrances and exits, and many other applications. You use a software called Jobgenplus and is in www.ute.com page. If you prefer, I can get an application, just tell me what you require, so it can give you a quote.
Algunas simbologias de codigos de barras pueden dar lecturas parciales (como el interleaved 2 de 5). Entonces verifica lo siguiente: el lector laser este limpio, y en la aplicacion puedes restringir la lectura a un numero fijo (8 por ejemplo) para que solo lea codigos de barras de longitud fija.
Some bar code symbologies can be read in part (such as Interleaved 2 of 5). Then check the following: the laser reader is clean, and the application can restrict the reading to a fixed number (8 for example) only to read barcodes of fixed length.
That message which your scanner is displaying is the normal and correct mode in stdby, there is no problem with it.
If the scanner says "bad command" is because you are pressing the "enter" (ENT) key without any command selected before.
