Question edited for clarity and all the typos / spelling errors.
Descale it again, but use CLR Descaler which is made for the job. I presume you can feel heat? When using the descaler shake the unit every 5 minutes because the steam valve outlet will be at the top. of the heater chamber.
If the fuse you are blowing is in your fuse box in house then your steamer is using more power than the fuse can carry. Move to an outlet powered by a larger fuse. Do not recommend changing fuse to a larger amp fuse because this could cause a fire hazard.
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Sorry to hear that! The burnt plastic smell indicates that the element over heated to a point that the heat radiation melted the substance. The internal heating element has shorted out and took with it vital accessories necessary for normal function of the steamer. Too many parts have become inoperative and the cost of repair is excessive. The only solution is to replace the streamer. Do not plug the defective unit into a live power outlet for safety reasons.
My wife has thrashed hers in her shop and it suddenly stopped steaming. It was about two years old. I managed to fix it. I dont think that the hose or the nozzel will be blocked because they are too wide a diameter. There will probably be a build up of silica or calicum inside. Unscrew the hose where it meets the machine. Remove the blue water tank. If you pour some water down the pipe from the end that you just unscrewed the hose , the water should well up in the depression where the tank sits through the little holes at the bottom. If it doesnt then the blockage is inside which is what I found. I used some decalcification liquid product ICL and poured it in from the hose end and let it soak for 10 minutes. Then I got a thin plastic tube to go in and scrape around as far as you can from the hose end. A thin bottle brush or pipe cleaner would be good. I then used a thin piece of wire to poke around the slits in the other end( depression) Then I emptied it out and continually flushed it through with water and give it a good shake holding your hand over the hose end connection hole. I found that when I emptied the water out , it contained all this silica and residue. I would have got about a teaspoon full in total. After several goes the blockage suddenly cleared itself and I found that suddenly the water was running through freely and welling up as described. I kept doing this until the gritty residue dissipated. You can hold the hose end under the tap and tilt the machine so that the water runs freely out through the depression well. I reassembled it and tried it out. Bingo just like new. Hope this helps. - Grant
design flaw: got it as a gift, and it leaked water. got a replacement, and it leaked water from the exact same spot. My guess would be that the water leaked into the wiring and shorted out. I still have mine, but empty it after each use.
