Sony Ericsson XPERIA S LT26I Nozomi Arc HD Logo
m
mohd shaiful Posted on Dec 19, 2013
How to remove password sony xperia LT26i - Sony Ericsson XPERIA S LT26I Nozomi Arc HD
How do u unlock password on a sony xperia lt26i
Do you want unlock sony xperia lt26i mobile network lock password? You can visit this site Unlocking4u.com here you can get the unlock code and unlock your cell phone. To get the code you have to mentioned which country is locked now,network provider and imei number. Then they send unlock code through email.
http://www.unlocking4u.com/sony-ericsson-lt26i/rs6wp9/
May 30, 2014 • Cell Phones
2helpful
3answers
How to nulock sony xperia s lt26i
solution 1, Hard Reset SONY XPERIA S LT26i with Software Menu :
  1. Make sure the battery is charge properly
  2. Turn on SONY XPERIA S smartphone
  3. Don't forget to backup all important data
  4. Go to menu: Setting > Backup & Reset > Factory Data Reset > Reset Phone
  5. Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA S
  6. The SONY XPERIA S will continue the step until ready to use in clean factory default.
solution 2, Hard Reset SONY XPERIA S LT26i with Flashtool applications:
  1. Flashtool in the applications from Sony can be download from Sony website.
  2. Flashtool software need to installed in you computer and ready with USB data cable
  3. Make sure SONY XPERIA S battery is charge properly or full charge
  4. Power off SONY XPERIA S
  5. Boot SONY XPERIA S to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
  6. Follow the menu at you computer display, it is easy to understand the steps.
solution 3, Hard Reset SONY XPERIA S LT26i with Hardware Key Button:
  1. Make sure the battery fully charge
  2. Do not forget to backup all important data
  3. Turn off the SONY XPERIA S
  4. Press and Hold together: Power Button + Volume Up Button for several seconds
  5. Follow the menu at LCD screen to continue the hard reset SONY XPERIA S
Be careful before doing this step to master reset, because all important data and applications will be removed from SONY XPERIA S, we always suggest you backup all important data before performing the hard reset.
How to unlock the screenlock on lt26i
I think the only way is to reinstall your phone's software using Sony update service.
1. Before you start you have to download the PC Companion software from Download for PC and install it on your PC.
2. Once installed on your PC, double-click the PC Companion icon on your desktop to start the update.
Note! For some models you will be prompted to do a backup prior to the update and then restore.
3. Install and open PC Companion then select Support Zone.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
Proximity sensor not working in sony lt26i
que puedo hacer para acceder a donde puedo desactivar el sensor de proximida [email protected]
Xperia s LT26i sim network unlock pin
To get Sim Network Unlock Pin for Sony Ericsson LT26I model phone visit the site Onlinegsmunlock.com
after getting the network unlock pin you can unlock it easily.
Sim network unlock pin
Hi, You can get he unlock code for a Sony Ericsson Xperia S from www.ProUnlocking.com at affordable cost with easy unlocking guide. Good luck mate.
2answers
Yellow tint
1helpful
3answers
Security code forgotten...sony xperia lt26i how to crack it or erase security question?
i have forgot the email and passwords, i forgot the pattern lock and also i do not remember the security question. How do i Ultimately unlock the phone and turn the lock off?? do i have to do a format or hard reset to clear off the passwords? - how do i do that??
3helpful
Need sony ericsson xperia LT26i pc suit
i want to update my system so i required pc suit
Top Sony Ericsson Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Sony Ericsson Audio Player and Recorder Expert? Answer questions, earn points and help others
