I no longer have the book and the stickers are worn off, having a hard time figuring out how to lock the seat belt that goes through the carseat. I did find a hook up high Behind the headrest but that does nothing for the bottom. Did not find any other mounting hooks, so I assume I have to use the seatbelt. But it won't lock, letting the carseat move. Thanks for any insight, and yes I've shut the airbag off too ; )
If you are able to feed the seat belt through the car seat, latch it then using the weight of your body and your knee in the seat push the car seat down and pull the seat belt out all the way until it stops. Once it starts reeling back in it will make a clicking sound letting you know it is locking. Feed all of the slack back into the reel and the seat will be locked into place.
SOURCE: Rear seatbelt stuck behind head rest in locked position
haha we know you didnt do it on purpose, without seeing your problem and the hard to describe issue, i can only recommend to maybe try folding the seat to the cargo position, if that helps. if not, then you will more than likely need to disassemble the rear quarter panel, and unbolt the seat belt retractor from the body of the vehicle. sorry but there is no other way
