SOURCE: Imagemixer3
Yes people I had the same problems too. To fix it I upgrade my system memory and installed a new video card. Now it work fine
SOURCE: video memory full on camcord, how to burn it onto a dvd?
First be sure to have installed ImageMixer software that came with the camera. If you can't find the disc go here... http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRSR40&LOC=3 then select your operating system and then select imagemixer to download.
Step 1:
Place camera onto docking station, connect usb cable to computer, open camera door, turn on camera. Imagemixer should open automatically, if not open up imagemixer.
Transfer to Computer:
Select "Viewing and Editing", then select "handycam" tap, click on "▼" (arrow) facing down, then click "movies". Place a check mark on each movie you wish to move to the computer then click "Options" tab (lower left corner) and see where the movies will end up once you click "Import to computer".
Burn to DVD:
Be sure you have a DVD drive that can write to DVD's. Will have DVD R/RW on the face of the drive. Place a blank DVD into drive. Follow Step 1. Then click "One Touch DVD Burn" from the imagemixer menu. Follow any instructions on screen.
Or you can choose to use Windows Explorer and select the drive letter that is your camera's harddrive and move/copy/cut/paste files directly from this location to another.
SOURCE: Flip Video Problem with deleting videos
What you guys need to do is empty the trash can on your mac before you eject the camera if you are deleting videos from your computer.
SOURCE: I lost the installation disc to my Sasmsung SC-DX103 camcorder
i have a jazz dv151 and the media card is saying is full. How do I solve the problem
SOURCE: I recorded a video on my samsung sc-dc 164
how did you transfer the video from the card to your PC?
did you connect the camcorder to your PC or did you use a memory card reader?
if you can play the audio then what you need is the right video codec for the unit
try searching for video codecs through search engines
make sure that the software that you are using to play the video plays the file format of your video,
try using roxio, then connect the camcorder to your computer via USB, make sure that the drivers are installed, play the video through your camcorder then use roxio to capture it real time instead of the usual "copy-paste"
