20 Most Recent Polaroid CAA-03040S Camcorder Questions & Answers
2answers
Hi there Im am experiencing a problem with my
Have you checked that the battery is charged? Try plugging it in and give it a few minutes to start charging, then see if it works while still plugged in.
11/2/2017 5:59:34 PM • Polaroid... • Answered on Nov 02, 2017
My camcorder indicates there is an sd card but will not record to it
Check to make sure the type of SD. card matches what the maufacturer calls for. Also the SD card may need to be formatted before you can record to it. Check your intruction manual to find out how to format the card. One last thing to check is if the SD card is locked. Usually on one of the corners there is a sliding tab used to protect and unprotect against recording over any material that may be on the card. Hope this helps.
1/26/2015 2:03:59 AM • Polaroid... • Answered on Jan 26, 2015
0answers
Wont power up
Be the first to answer 4/16/2014 3:57:31 AM • Polaroid... • Posted on Apr 16, 2014Be the first to answer
0answers
I need the drivers for
You can go to the official website or check if there was any software that came with it in the box
11/5/2010 3:42:43 AM • Polaroid... • Answered on Nov 05, 2010
The lcd screen stays lit
So, you need to have the sensor replaced. It would be best if you took it at an authorized service center.
8/28/2010 7:10:44 PM • Polaroid... • Answered on Aug 28, 2010
Every time i try to use it it says card protect
SD cards have a small slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
3/16/2010 8:28:01 PM • Polaroid... • Answered on Mar 16, 2010
Looking for drivers
don't see your model in polaroid.com
but you can try if is there what you want from here http://www.lostmydrivers.com/cameras-and-mp3-player-drivers/polaroid/
2/15/2010 7:22:03 PM • Polaroid... • Answered on Feb 15, 2010
After putting fresh batteries in, the video
first thing to check is to make sure you put the batteries in the right way.
but the problem is usually the type of batteries used.
make sure you use the batteries suggested to use in the manual.
if you use cheaper batteries the problem does happen. if you are using high end batteries then the problem is sometimes a short in the camera and its shutting down to protect itself from further damage. you will have to take it in for repair.
hope this helps.
1/8/2010 12:27:52 AM • Polaroid... • Answered on Jan 08, 2010
Camera only works without the sd when the card is
Hi!
Try to reformat the the SD card. You can do this by inserting it on a card reader and then plug it on your PC. When the computer sees the card, go to My Computer, right click the SD card and then click Format.
10/26/2009 3:39:33 PM • Polaroid... • Answered on Oct 26, 2009
The software will not download into my laptop Acer
internet setting problem
or you firewall setting.
10/9/2009 1:24:16 AM • Polaroid... • Answered on Oct 09, 2009
How 2 use as a web cam
Did a disk come with it? Download any drivers you need. If you must, go to manufacturers website. Microsoft has camera wizard that pops up when you plug it in with USB cable. Lemme know. Please rate me
6/18/2009 2:23:45 PM • Polaroid... • Answered on Jun 18, 2009
SD protected removal of polaroid 5070
is your SD card locked unlocking this may help you
1/25/2009 1:29:34 AM • Polaroid... • Answered on Jan 25, 2009
Locate battery compartment
On the side
1/25/2009 1:28:10 AM • Polaroid... • Answered on Jan 25, 2009
My camera is broken
Well, I hate to say it but that sounds like a job where you're going to have to pry open the shell, or take it to an electronics shop and have them do it. What most likely happened is that one of the wires, resistors, Capacitors (the capacitor makes an electric current larger, resistor makes it smaller) was disconnected, so the power cannot get the the motherboard (main "computer") and power the camera.
1/19/2009 8:47:22 PM • Polaroid... • Answered on Jan 19, 2009
2answers
Turning off
Simply closing the flip open screen should turn it off or there is a power button under the screen.
12/25/2008 2:41:20 PM • Polaroid... • Answered on Dec 25, 2008
Polaroid CAA-03040S Camcorder Logo
Popular Tags
45 questions posted
Top Polaroid Video Cameras Experts
Tony Parsons
Tony Parsons
Tom Chichester
ray gallant
Are you a Polaroid Video Camera Expert? Answer questions, earn points and help others
View Most Popular
  • Polaroid Video Cameras
Most Popular Question
camcorder indicates sd card but will not
  • Video Cameras
