The vocal content of the music, is generally handled by the midrange driver. For more information, please visit my website at audioserviceclinic.com. Thank you.
Hey there! When it comes to the Cobra 29LX Bluetooth, there are a few mod options available to enhance its capabilities. However, it's important to note that modifying your radio may void any warranties or legal certifications it has. So proceed with caution and at your own risk.
Now, let's talk about adding a tune talk back voice to your Cobra 29LX Bluetooth. The tune talk back feature allows you to hear your own voice through the radio's speaker while you're transmitting. This can be handy for checking your audio quality or making adjustments to your voice modulation.
To install tune talk back, you'll need to follow a few steps. First, you'll need to open up your radio's casing and locate the talk back circuit. It's typically a small board with components related to the talk back function.
Next, you'll need to identify the audio input and output points on the circuit. These are the spots where you'll connect the necessary wires.
Once you've identified the right points, you'll need to solder a wire from the audio output of the radio's microphone circuit to the audio input of the talk back circuit. Make sure to be careful and precise with your soldering to avoid any damage.
After the connections are made, you can reassemble the radio and give it a test. You should now be able to hear your own voice through the speaker when you transmit over the radio.
Modifying your radio can be a bit complex, and it's crucial to have a good understanding of electronics and soldering techniques. If you're not confident in your skills, it's always a good idea to seek assistance from a professional or someone experienced in radio modifications.
I hope this explanation helps, and if you have any more questions, feel free to ask!
Bad news...you've blown the tweeters. Overdriving the mixer/amp creates distortion on the amplifier which heats up the speaker voice coils and eventually causes damage. Because of their small diameter voice coil windings the tweeters fail first (opens up like a fuse element does) followed by the woofer making a scraping sound (deformed voice coil) or not working as well. Warranty service because you blew out the tweeters? Don't get your hopes up.
1. PLEASE use enough power for the venue that you have. A high powered system will run all night at 10:00 (physical volume knob setting) than an underpowered system set for 2:00.
2. Get speakers off the ground and closer to your audience's ears. Audio from speakers on the floor must battle surfaces that actually absorb some of the sound....carpet, drapes, etc. And besides, legs can't hear that well.
Have your unit brought back from where you bought it,
the phone mic piece or microphone is damaged this should be replaced, thats why they cant hear you.
I would not recommend it replaced by yourself, this would void your warranty, and e63 phones is quite sensitive
if you cant hear caller voice. do one thing go to gallery and go to voice recorder and record some voice then save that then go to media and play recorded sound if its working means your loud speaker is working but not ear peic means (ear speaker) not working. so then you need to change ear speaker.you can do your self just watch video on online.
try checking your mobile's mic.. maybe its fault due to exposure to water or mobile dropped....if you urgently need a solution try to make calls vai head set.... or else you've to service...
you need to install the smart audio driver 221 for your laptop the mute problem should be solved with that and should increase voice qty a little. I guess you are using Win XP
