SOURCE: Panasonic viera
1.You may have the magnet of a speaker too close to the TV.
2.Turn off other electrical devices in the house one at a time.
3.Faulty cable.
Puzzler.
SOURCE: Have a Panasonic TH-50PX500U plasma TV. Color go's to blues
check and reseat all the connections on your T-con board which is located in the midle top of your unit there will be a cable from the mainboard and 1 or 2 from the top to the panel carful those connectors are cheap clean with rubbing alcohol
SOURCE: 50" plasma panasonic 720p tv has several colored
Flashing error codes could be the Direct tv box itself.Because tvs have problems within itself don't flashes error codes on the tv screen,the problems,just show up.Tries tv and Direct tv satellite box unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting and the Direct tv box updates it softwares data's.The problems should be solved,if have the same problems,first call Direct tv for a replacement box,see how it work out.Than turn ur attention to the tv.
Tried cleaning cables and reconnecting didn't work. When the cable box booted up there was a screen that said user settings black screen white writing, when the cable tech had me hit it in remote that is when color went away. Cannot get back to that screen. Also put a DVD in it played perfect with sound! So it is something in the tv settings!
