Resetting company voicemail
Norstar Common Voicemail Features
To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your
password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave
a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all
together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your
voicemail box
3. If the call is answered by the company greeting, or your personal greeting,
Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your
recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or
out of the office.:
1. Press the Check
5. Pres the REC softkey
6. Press the ALT softkey
recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting,
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have
your voicemail box accept messages while your Alternate Greeting is turned on,
or press the CHNG softkey to change the "Y" to an "N" if
you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail
box and have it play the PRIME greeting
took this from a guide i have, might help you guys out
