Electric Wheels Ew-36 Mobility Scooter Orange Logo
A
Anonymous Posted on Oct 25, 2013
My EW36 won't go into reverse - Electric Wheels Ew-36 Mobility Scooter Orange
Where do I find the Tire and Loading Information label?
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U can also get free manuals
Mi Ew36 is about 6months old, but now the charge lasts only half the distance compared to when it was new. What could be the problem?
First, I'm not a EW Tech.
* Check your warranty and call for service.
*** The following is for information only.***
* Most power loss and low power stem from blown fuse(s), broken or burnt wires and/or connectors. Locate and replace bad wire.
* Problems with charge or gradual power loss is usually the battery system. Since this is most likely a Lead Acid battery (flooded or Gel) then those need to be checked (load tested) and replaced. Do not expect these batteries to last forever. Most will last about +200 charge cycles. Less if the battery is stressed (deep discharged,High temperatures, Over charged).
* Lead Acid batteries concider a charge cycle to be when ever charging. Even if the charger is removed prior to a full charge and discharged, this is still a charge cycle. Short charging is not recommnded. Top off charge is a cycle charge.
* Follow your MFR charging instructions.
* Check Battery; https://www.youtube.com/watch?v=mgEiNp8l_PE
* Check Fuses; https://www.youtube.com/watch?v=rgK2l6cMCc4
* Review EW36; https://www.youtube.com/watch?v=K_NcgxUgAvE
* you may want to upgrade to Lithium Ion Battery Pack (with BMS) which will have a higher cycle rate (+1000)
Aloha, ukeboy57
Bike wont move brand new.
probably a safety switch that you have not switched on
read the user manual thoroughly or have the retail shop come and explain the operations to you
That way if it is a warranty problem , they can take it away and have it fixed
Ew36 scootor wont move
Hi Sharon,
out of 20 of those models I have repaired 2 have been a throttle fault however 10 of them where controller faults. are you located in the uk ?
Regards
2013 EW36 ewheel scooter. Why doesn't it start?
I think the the fuse is under the head light cowling glass type 25 amp fuse. Your throttle, motor wiring, or controller maybe causing this problem.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
1helpful
Can i get a scamatic
hi u can get the owners manual [pdf] download at www.manualslib.com .........cheers
How do you adjust the speed restricter?
normally this is programed into the motor controller and not adjustable by the end user
2008 Saturn vue won't go out of park and shows it being in reverse and won't start.
Broken shift cable ?
If the neutral safety switch is on the transaxle and the cable is broken, the switch could still be in the reverse position.
Top Electric Wheels Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Electric Wheels Health and Beauty Expert? Answer questions, earn points and help others
