Headlight only comes on when the neutral lamp is illuminated. Any other gear and no headlight. Maybe a ground issue? Any hints where to look?
SOURCE: change headlight
Doing a search I saw your question come up, hopefully this is not an old question. ANyways, under the front edge of your fairing there is a small black rectangular plastic piece held on with 2 screws and two clips. Remove the clips by pulling on the centers, they should come right out, this will give you access to the back of the headlight. There you will need to unplug the headlight and the give the light a turn and it should come out of there. Make sure not to touch the new bulb with your bare fingures as this will shorten the life of the bulb, clean with alcohol if you do, hope this helped.
SOURCE: Honda Shadow 600 c won't start in gear after battery change
The kickstand switch is either bad or bent out of position. See if you can activate the switch manually. Does the bike run now? If so, the switch is bent out of position. If it still won't run, jumper the wires together until you can replace the switch.
SOURCE: i have a 2000 heritage after riding for about 20
Try to change the sparkplug.Try to change the gas.maybe there's a water mixed.
SOURCE: headlights will not come on and it will not start.
sounds like you have no connection at a major junction block in your wiring that will be running to you ignition and kill switch.. Look for a green (corroded) or loose connection. Also first would clean all battery connection!
SOURCE: 2009 hd flhx headlight lamp removal replacement
1 remove the screw on the bottom of the chrome ring 2 remove the three screws from the retaining ring 3 pull headlight out and unplug.To remove the bulb remove rubber boot and push down on wire loop and push end out from under the retainer lip (you can loosen the screw 1/2 to1 turn if needed) remove bulb and replace. The new one turnso that the wider ear is pointing up (use the emblem on front)
