Sir i have nokia 6700 slide my mobile network signals is very low please tell me what i can do i am very confuse..:(
SOURCE: no network signals in nokia 2630
look Mr Neeraj.
First i need u to restore the settings of the phone.
check the following:
Menu>Settings>Restore Settings
The Default Security Code is 12345
if thas is not helping u:
this problem Occurs when the PIF Chip its a amplificator Chip that amplifies the signal when the antenna catch it ..
u need to replace that part. (take it to a trusted* phone repair man cuz its not an eszay task at all)
i reapeat u shud perform the pervious in case if the ressiting process not help.
plz do rate this post as good as u can .
so we can help others.
*some of the phone repair mans take parts from phone so watch out.
SOURCE: NOKIA 6500 SLIDE , NO NETWORK CONNECTION
plz backup ur data : contacts msg photos and try this code
*#7370#
then 12345 as the default security code
if that not working
the PIF is faulty its a amplificator circuit in the borad shud be replaced
SOURCE: nokia 3100 network signals disappear
You must change PA(Power Amplifier) IC on your phone.5-6second signal than gone is a sign of PA IC not work any more.You know that PA is an IC where phone use to transmit.I hope it help.
SOURCE: My mobile has a special problem. The mobile shows
Are they the same models?
The phone's capability to sustain a stable network coverage may vary even in model types.
While at your home,remove the phone's battery and simcard and fit them again.
Note how the phone's network signal registers.
It may start very high and then drop drasticaly to very low or no signal at all or sustain a constant signal reception.
If the reception's good in other areas,then your home area's network coverage may not be that good.
Hope this helps.Thanks!
