SOURCE: this site is a joke trying to get operating manual NO LUCK
here is your manual in pdf form enjoy
http://www.cbtricks.com/radios/connex/cx4300hp/graphics/connex_4300hp_om.pdf
please give feed back for this I also hoop it is the right one.
SOURCE: How do i peak my connex 4300hp?
They probably still have more experience then you do! You should be okay as long as you tell them that you just want a basic peak and tune. Nothing crazy. If you ask for super mod of some kind then you will end up with a radio with problems.
You can also send it out to have it peaked and tuned.
50 watts isn't bad tho. I have never worked on a connex and don't know much about them so I couldn't tell you who to peak it out.
SOURCE: does anyone know the pod too turn for lowering the watts
You have to adjust the high key first so make sure you're rf power is on high, hope you have a meter set it on the 20 watt scale, key up and turn vr 13
located in back of radio infront of where you're coax connector is until it keys around 12 watts, thats where most connex 33hp should be set,now go to low power and key adjust vr 16 right net to the otherone down to about 3 watts, now you can drive a liners. Mod is Vr 2 right below them two. whistle in mic and turn to get the mod you want.
SOURCE: got a connex 3300HP has
You may have a dead meter.
Modulation is audio's affect on swing wattage or pep. Notice that needle moving more with your voice.
Dead key or carrier wattage is without your voice enhancing the power only with mic keyed.
I can only assume that the chipset you are referring to is an ic chip audio or pll which must be working if you are receiving audio.
Check your mic cord................ transmit and modulation and even your receive volume can be affected by the cord/mic plug solder joints or broken wires here.
http://www.cbtricks.com/radios/galaxy/dx33hp2/graphics/dx_33hp2_sch.pdf this is a similar radio the General Lee, Connex 3300hp and Galaxy hp2 share boards i believe dont hold me to that thou.
