20 Most Recent Connex 4600 Base CB Radio Questions & Answers
I have a connex cx-4300 hp it's has poor receive I want to turn up receive a little bit I guess what I'm asking is what tuning pod tunes the receive
Connex 4600 Base... | Answered on Mar 11, 2019
I have CX-4600-T too. Mine gets way hot as well, I had a mod kit installed n it swings 215W peak power now. But the excessive heat is annoying, I think mine does have a fan in it though cause I know I felt air coming out the back before.
Connex 4600 Base... | Answered on Dec 19, 2018
i have a 4600 connex and if i turn the mic gain all the way up i get alot of modulation.can someone tell me how to fix that?
Connex 4600 Base... | Answered on Dec 24, 2015
Hi there!!
The Connex 4600 Turbo is a very sensitive radio these radios don't work good at all with the stock microphone! The best microphones are the RK-56 and or the Astatic 636L which most people use and you shouldn't get any squeal. And make sure if that you are using an external speaker get it as far away from the radio as you can facing away from the radio so it wont feedback. As far as a Mod kit there are several ways to modify the radio which most are pretty hard and drawn out. but the most easy that used to be used is as simple as a diode placement in the right place which is old school but still works good. You must be very careful as if you are to slightly touch the wrong points the radio could be destroyed and no longer work so caution is to be taken if you don't know what you are doing please don't try it on an expensive radio!! If you want more info on the mod e-mail me
never the less a Modulation kit or modification wont help your Receive it will only help your Transmit signal!!
Dennis
Connex 4600 Base... | Answered on Mar 05, 2015
not really.Many radios come with one built into the meter on the radio. For those with none you will need an external SWR meter. I would recomend a trucker 2000.
Connex 4600 Base... | Answered on Aug 13, 2014
turn down your mic gain and that should cure it.
Connex 4600 Base... | Answered on May 18, 2014
cold solder joint somewhere
Connex 4600 Base... | Answered on Nov 26, 2013
The only thing that comes to mind is to make sure the antenna is well grounded and to make sure that where it's been re routed that there are no power wires next or close to the antenna wire which can cause interference which will be more noticeable once you turn on the truck.
Connex 4600 Base... | Answered on Sep 23, 2011
Well it does sound like a bad solder joint around your crystal,crystal is what gives you your freq.or channels.All I can do to help you without it being on my bench is to tell you to take the screws out the top of the radio,run the radio and when it quits lightly push on the top of the radio and see if that helps,if so it is a bad joint just find a cb shop that will take the time to find it.These are great radio well worth fixing.
Connex 4600 Base... | Answered on Jul 10, 2011
Strange. You shouldn't have a squealing problem with an RK56 noise canceling mic.
Unfortunately there is no way to change the volume of the talkback. Its too loud. The only solution is to turn the mic gain down.
The only reason you need to have talkback on is to check your audio. Make sure the echo is good and what not. After that you really don't need it on. So turn down the mic gain, then check the echo, then turn off the Talkback and turn the gain back up.
The squeal is feedback from the talkback being to loud and being heard by the mic. So the only way to solve it is to lower the volume of the talkback, (Which is not possible in this radio) lowering the mic gain(which lowers your audio level) or turning it off.
Connex 4600 Base... | Answered on Feb 10, 2011
check coxail& antina
Connex 4600 Base... | Answered on Jan 03, 2011
have you tried CB Tricks .com they should have what you're looking for if you take your time to find it there.
Connex 4600 Base... | Answered on May 14, 2010
This is a 190 watt radio it needs 8 guage wire and ran to battery source.
Connex 4600 Base... | Answered on May 01, 2010
Bad RX/TX Transistor? I don't have a diagram for the 4600. Sorry!
Connex 4600 Base... | Answered on Apr 03, 2010
Radio Communications Logo
29 questions posted
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Connex Radio Communications
Most Popular Question
frequencies
  • Radio Communications
