Code p0016refers to the crankshaft /cam shaft position sensor bank 1 sensor A-- correlation===causes---Wiring CKP sensor--CMP sensor--mechanical fault Check timing belt is not broken
code po113 refers to intake air temp (IAT) sensor--circuit malfunction===causes ---wiring open circuit/short to positive--wiring short to ground---ground wire defective IAT sensor---ECM
code mp0700 refers to transmission control system/MIL-malfunction===causes--wiring ---TCM
code po562 refers to system voltage low==causes---wiring poor connections---battery---alternator or it also refers to ECM power relay control--circuit open===causes ---wiring--ECM ---relay. For this one check the battery terminals and posts are shiny clean and tight . Have a load test done on the battery to check for faulty cell. check condition of alternator drive belt and check alternator out put.
SOURCE: code 301, random or cylinder 1 misfire
Spake pluge could have gone bad, or the Spark Plug wire. Try changing all your plugs and wire and inspect the old one's. The wire could be bad do to time or may have been against the exhaust manifold and brunt. Good luck
SOURCE: Code PO442 & PO455 on a 2003 Dodge Caravan with 3.3 engine
The problem is most likely to be with your vacuum line they put cheap rubber hose for this purpose. You should find a diagram at the front of the vehicle trace the hoses by this diagram. You most likely will find a bad piece of hose.
SOURCE: 2005 dodge caravan engine light code p 441
If you mean code P0441 - This Relates to Incorrect Purge Flow for Evaporative Emission System
SOURCE: Failed Emision test
po442 is evap emission control system leak (small) 1 of the lines for emissions is leaking. po455 is-- emission control system leak (large). turn off light with code scanner after it is fixed.
SOURCE: how to install front struts for a dodge caravan
the strut mounts on top with three studs and on the bottom with two bolts to the spindle support, you will need a spring compressor to exchange the spring, its a good idea to install new bearing plates, when reassembling make sure the spring plate is lined up properly, get repalcement cam bolts for the bottom and then get the vehicle realigned, while you are it its a good idea to check the ball joints and tie rods for any looseness,
Testimonial: "Thank you for the answer ,it was a stepping stone which help me to get the job done"
