SOURCE: Electrolux EOB5630 oven cuts out
First thing you would want to check is, make sure you don't have any issues with the electrical connection to the oven first. Possible cuircut breaker issue.
Check these things first, you are probably going to find a loose connection somewhere. If that doesn't fix your problem.
Let me know and we can go from there.
SOURCE: HI, MY ELECTROLUX SINGLE FAN
have you set the time on the oven? this brand won't heat up unless a time (any time) is set on the clock...
SOURCE: Electrolux EOG600WN gas oven trips out circuit
You have a shortage in your wiring system and you'd need to call for service.
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
SOURCE: My electrolux EOD5330 fan oven tripped a fuse. ow
Most likely problem is the the oven element short circuited which caused the fuse to blow. When power is restored everything generally works except for the element. If you check the element you may find a blow hole in it.
