The F10 F11 F12 F13 F14 Error Codes indicate that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa
it has happened to me several times if a little water gets onto and maybe down into the display. I bought $9000 dollars in electrolux appliances in 2010 and have had problems with all which include gas stove, microwave, dishwasher and refrigerator. dont buy them. too much money and they are garbage.
Had an F11 code, unplugged and measured the temperature sensor.
Resistance check passed. After plugging it back in everything is fine.
Re-seating the connector seemed to have solved the problem! Hope you
have the same luck.
Kevin
Hello Nancy Keller - Typically, error code F11 indicates a shorted keypad. Try resetting the wall oven by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
