SOURCE: My windshield washer fluid is not pumping out to
Remove the small tube that's attached to the fluid tank and press the wash button.
1 - If fluid isn't gushing out take out the connector to the pump and connect a light bulb to it. If the bulb lights up when you press the button the pump either is busted (replace it) or its connectors are corroded (clean them).
2 - if the fluid is gushing out then it's a blockage somewhere down the line; put the tube back in the tank, find and disconnect the other end, press the button. If it doesn't work then you have found the culprit - replace it. If it does flow then continue till you locate the blocked part.
SOURCE: 1998 Grand Prix GTP windshield washer (full) not pumping fluid
Yes it's easy to do, remove tank pull pump off of tank, and replace pump, Napa has this pump # 6651533 it runs between $14.00 and $20.00 .
SOURCE: How do I replace the
That sensor can be replaced. It's located on the washer fluid bottle which is found behind the front bumper and next to the passenger's fender.
