Try to reset to factory reset through RESET button on device. Normally it's the POWER button. Press and hold the power button for approximately 10 seconds, your device will reboot.
Keep disconnect the car's battery for a longer period of time to ensure that the radio's memory is fully cleared. Be sure to have the car's security code on hand, as it may be required to reactivate the radio after reconnecting the battery.
If none of these steps work, there may be an issue with the radio's hardware or software that requires professional repair. It's best to have a qualified mechanic or car audio technician diagnose and repair the issue.
cartech.about.com > ... > Car Radio Components FAQs, and More
First your battery went dead, and now your car stereo is dead, and it's really ... or charge, and you're lucky, then you may find that your car radio fuse is blown.
Nov 30, 2011 - Today the dealership did a tuneup, replaced the timing belt, and put in a new battery. I started my car and the radio did not work. They went out ...
Jul 18, 2011 - Also now the battery has been recharged the redio will not work. .... Mybattery went flat, took it out and went to a battery shop who charged it up ...
I would go to a Renault Dealer vs: trying to use the phone, & just ask one time, what the procedure is, for getting as well as entering the radio code
Not all vehicles require doing that. If your does,write everything down, as you will have the battery cables off or other issues as time passes.
No one on the internet should know your VIN# or would have a code for anything. That is the purpose. So if your radio is stolen, it won't work in something else
you'll have to contact the dealer. They are the only ones that can fix it. If you bought it from them, they should be able to give you the code over the phone.
You must go through your local honda dealer, (usually parts department) give them the numbers off the labels on the radio, along with the VIN number of the car. may have to prove ownership. They can call Honda and get that information for you. Process is alot easier if you someone that works in the parts department, if not the honda parts department, then another parts department at another car dealer.
If you disconnect your battery for an hour and then reconnect, the dvd will just pop right out. This happened to us, Honda did not know how to fix it and they wanted me to pay $400 for a new one. But while they were trying to figure it out they were sticking screwdrivers and pens into it and have now broken the whole system and refuse to pay for it.
you can only try the code install 3 times before the radio locks up.
you will have to disconnect the battery for 10 seconds if that happens. the 5 digit code gets entered where the station select buttons are 1 2 3 4 5 6 enter the code there.
time for a trip to the delaer.
