Cars & Trucks Logo
Michael Brett ward Posted on Jul 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I hooked my battery up backwards now the ignition won't turn over when I turn the key. It also sounds like its not getting fuel
Layne Johnson
Level 3:
Master:
  • Master 379 Answers
  • Posted on Jul 20, 2013
Layne Johnson
Master
Level 3:
Master:
Answers
379
Questions
Helped
90937
Points
1144
Hooking up backwards basically fries everything first take the starter and get it tested you problly fried the solenoid but pray you didnt fried your igniton switch on the car and as for the fuel you most likley poped the fuse pray that it is the fuel beacuse a new fuel pump can cost ya a good amount
Hooked up battery backwards now engine isn't
No. Replace the Engine control unit that was destroyed when you reversed the polarity to it.
The 'key in ignition' warning sound won't turn off and my battery went dead. How do I get it to turn off?
Pull the Battery Post off the Battery then the fuse If that don,t work Cut the Horn Wire To It
Key won't turn in ignition on 2006 chevy cobalt
on a lot of these late model computer base cars when battery power get low the computer gets confused. try this disconnect the neg. battery cable. charge the battery. reconnect and try again. my son cobalt battery went bad key was stuck in the igntion. good luck.
1helpful
Changed out motor on 97 grand am but now when i hook up the battery the parking lights come on without the key in the ignition?
first sounds like the wires to the starter are right,they may be cross or backwards. the other are you sure all the wires are collected. .there is a wire from the fuse box the the starter. I do motor swaps all day in my garage.https://www.facebook.com/TedsRepairs
It's turning but won't start. Have power.
Clean the carburetor and add a fuel cleaning additive to the tank. That should do it. Your alternator should be fine, but get that checked if the other suggestions don't work.
Why is it when i turn the key foward radio don't work and truck won't fire but when you turn the key backwards the radio comes on
You don't say what kind of vehicle we are talking about, but it is safe to assume your ignition switch needs to be replaced.
1helpful
GMC 2000 sierra pick up 1500 sounds like it wants to start but won't turn over. Battery sounds good so I guess battery and alternator are ok. For several years fuel gauge doesn't work and...
It sure could be. But, first...by "won't turn over" you do mean it cranks at normal speed but won't start?
A simple test of the fuel pump is to stand by tank and listen as someone turns key to on. When first turned to on, your pump will activate for 2 or 3 seconds, pressurizing the fuel system, and then shut off if the engine computer doesn't get a cranking signal. Do you hear it come on? If not, then something's not turning your pump on. If you can hear it buzz on briefly, then maybe it's your filter. Another test: Spray a little starting fluid into your intake manifold (remove the big hose going into intake manifold) while someone tries starting it.If it doesn't fire and try to stay running, then it's probably an ignition problem. But if it does fire off, then you know it's a fuel problem-likely your pump or filter. good luck.
1995 geo tracker won't start. I've replaced everything except the ignition switch. It used to click when i turn the key, now it won't even click.
DISCONNECT YOUR BATTERY AND RECONNECT, THIS SHOULD RESET THE BRAIN.
ALSO...WHEN YOU TURN THE KEY, LISTEN TO HEAR IF YOU CAN HEAR THE FUEL PUMP COME ON...IF NOT, GUESS WHAT? HOPEFULLY NOT!... BUT,YOU MAY NEED TO REPLACE THE FUEL PUMP, IF YOU CAN'T HEAR IT WHEN YOU TURN THE KEY, AFTER YOU'VE RESET THE BATTERY!
HOPE THIS HELPS!
1998 Jeep grand cherokee Laredo turning over but won't start. It sounds like it wants to start but just won't power into it. We changed spark plugs w/in last year, brand new battery, the alternator...
When it sounds like it wants to start but won't, it is almost always a fuel problem. When you first turn on the ignition key (radio off, in a quiet setting) do you hear a faint 'hum' from the rear of the car? If so, your fuel pump is probably alright, so the next check it to remove the small, light green plastic cap (it might be black, about the size of a tire valve cap) on the top of the engine-it is part of the fuel rail and has a small pin in the center of it. With a rag in your hand, hold it over the valve, and with the key on, use a small screw driver and push the pin in-the rag will keep you from getting sprayed, if all is alright, but if you get little or nothing, you have a problem with your fuel pump, filter, fuel regulator or you may have a plugged 'sock' at the bottom of the tank.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
