Cars & Trucks Logo
Anonymous Posted on Jun 03, 2013
2002 Pontiac sunfire front and rear left speakers not working ! Any idea what could be wrong ? I heard there is a factory amp do you know where that would be and if that could be the problem
David Fuell
Level 2:
Sergeant:
  • Expert 290 Answers
  • Posted on Jun 03, 2013
David Fuell
Expert
Level 2:
Sergeant:
Answers
290
Questions
Helped
48859
Points
870
Factory amps are located on the stereo unit itself or in the trunk but only if the car was ordered with premium sound and the possibilities of that car being ordered with premium sound is unlikely. so at the harness in the back of the stereo find the speaker wires and hook up a 9 volt battery to the said speakers that dont work if they crackle then its in the stereo if not its the speakers or wires to speakers with battery hooked up and speakers dont crackle go to speaker and test with a vom and test for 9 volts dc
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Mar 16, 2009
SOURCE: 2001 Sunfire rear brake/turn signal don't work.
check your fuzes. if that doesnt do you any good maybe a flasher or check for bad wiring. maybe a short somewhere
Anonymous
  • 290 Answers
  • Posted on Mar 26, 2009
SOURCE: needing wiring diagram for 1991 dodge dynasty le
here is what I found:
http://www.the12volt.com/installbay/stereodetail/715.html
Anonymous
  • Posted on Feb 21, 2010
SOURCE: 2002 Pontiac Sunfire rear brakes
Yes i fixed the problem i had to remove my backing plate and grind them smoth where the brake shoes rub on them then. I put some high temp brake grease between the shoes and the backing plate works great now!!! seems like the backing plate gets grided down by the metal from the brake shoes throug the years.. You will see the metal on the backing plate will have some ridges on them so make sure you grind them smoth
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Apr 03, 2010
SOURCE: rear brake diagram for 1996 pontiac sunfire
take both drums off the do one whilst looking at the other in case you forget where that little spring went
Anonymous
  • 381 Answers
  • Posted on Nov 18, 2010
SOURCE: My 1999 Pontiac Sunfire's left
Your turn signal switch in your sterring colum is bad. The turn signal canceler in the switch is bad causeing both brake lights to be canceled all the time. Common problem
3answers
2004 sunfire ignition key wire does it have one/ instaling new radio only have constanyt 12 volt radio power on off button does not shut off do i use this wire and where does it go the ignition wire...
Hi, your factory Sunfire wire colors are pasted below. The yellow wire should be accessory. This should connect to the stereo's red power wire. The orange "always hot" wire should connect to the stereo yellow wire--this is only used to keep your station presets in memory. Please let me know if you have more questions, and thanks for using FixYa.
2004 Pontiac Sunfire Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
1helpful
2answers
Stereo wiring
Check this wiring for Pontiac Stereo...
For Other Pontiac Models
Hope helps qith this (remember rated this help) Good luck.
3helpful
2answers
I need to know the speaker wire codes for a 98 pontiac sunfire
4helpful
Need radio wiring diagram for 2000 pontiac grand prix factory diagram
2000 Pontiac Grand Prix Car Stereo Wiring Guide
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Audio Front Speakers Location: Dash
Car Audio Rear Speakers Location: Rear Deck
13helpful
2answers
Factory radio wiring color codes
Here ya go. enjoy!
2002 GMC Sierra C1500 Car Radio Wire Color Codes
Car Radio Ground Wire: Black/White
Car Stereo Amplifier Location: Under the center console.
Durango Radio fade does not work
check the connection atr the back if their ok or maybe you just have a loose wire on it...
1helpful
Install new cd player please help
HERE U GO.
2002 Pontiac Grand Am Car Audio Wiring Diagram
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Stereo Amplifier Location: Mounted behind trim in the left side of the trunk.
I need color audio color codes.
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Right Front
Front Speakers 4" x 6" Doors
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Feel free to re-post if you require additional information.
Also, the brand/model# or radio is helpful if looking to re-install it.
Thanks for using FixYa - a FixYa rating is appreciated.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
