Gigabyte GA-8I848P-G Motherboard Logo
edy pur Posted on Mar 17, 2009
Led pwr+hd isn on, cpu fan is runing, but no
Led pwr+hd is on, cpu fan is runing, but no post(monitor isn't on), vga, ram, bat cmos, cpu was change.., but still no working. help please.......
  • edy pur Mar 17, 2009
    then what can i do to fix this trouble....? TQ
    yes i'm hear the any beep if i remove ram & start the computer
Mohit Tiwari
Level 1:
  • Contributor 35 Answers
  • Posted on Mar 17, 2009
Mohit Tiwari
Contributor
Level 1:
Answers
35
Questions
0
Helped
7131
Points
78
If your monitor is working properlly,then you should check the following things:-Remove ram and start the computer. If it gives you any beep then your motherboard is all right.And if not,then it's time to buy a new motherboard.
  • Mohit Tiwari Mar 30, 2009
    your monitor is not working well. Check your power cable and data cable of your monitor.
My fan is running but it won't load windows. The monitor says power saving mode
Check the NUM LOCK led status when power on the computer if it is on and off when you press num lock key that means your cpu is working fine only issue with screen resolution for that when you power up th computer press F8 key 5 to 6 times then you can see safe mode and other menu.Enter in "enable vga mode " then go to display settings change scree resolution to 1024*768 then check. but if num lock led stay constant then open cpu cabinet cover reconnect RAM memory.Pull cmos cell from motherboard for 10 minutes then put it back. Reconnect pci or vga card if any. Reconnect processor and it's fan. Make sure motherboard is not ground with cabinet.Also make sure harddrive is recognized in bios if you are able to see bios. For that when you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then check. Let me know if you need further assistance. Thanks for using Fixya.
I have a MSI MS-6566 Ultra-C v1 with an Intel 2.6MHz CPU. The board is getting power and the CPU fan is running along with the fan on the AGP video card, but the CMOS will not post. The PSU tests fine. ...
have a problem with v1.5 a6566ims always ask if in start setting bios date month and year, and the second when the computer restarted there was no display on the monitor even though I have changed battere, VGA or memory, whether the BIOS has been damaged? what should i do please help. thanks
How do I fix my computer moniter?the screen is black
When you power up then after 12 seconds check the num lock led status on key board press num lock key then if num lock led is on and off then your cpu is working fine.
For that make sure vga adapter from monitor is connecxted to cpu is properly.Then when you power up the computer press F8 key then you can see some menu enter in "Enable vga mode " then go to display property and change screen resolution to 1024*768 then apply and check.
But if num lock led is constant then then you need to open cpu cabinet cover.
Then reconnect ram memory .Try it in different ram slot.Make sure motherboard is not ground with cabinet.REmove pci or other card if any.
Then check.
Pull cmos cell from motherboard for 10 minutes then connect again.
Also reconnect processor and it's fan then check.
Thanks for using FixYa.i
Problems with E-Machines eMachines Monitor, screen is white computure, does not come up.
First check num lock led status on key board when you power up the computer if it is on and off when you press num lock key then your cpu working fine but if it is constant then you need to open cpu cabient reattch the RAM memory pull cmos cell from motherboard for 10 minutes.Reattch the processor and its fan.
make sure motherboard is not gorund with cabinet.If you have vga card then reattach into its slot.
But if num lock led is on and off then when you power up the computer press F8 key then enter in enable vga mode then go to control panel->display property ->settings then change screen resolution to 1024*768 then apply and ok.
My HP Pavillion keyboard lights up but the screen is blank what can i do?
Press num lock key of key board if num lock led is on/off then your cpu gives display to monitor Then make sure monitor cable is connected properly to cpu vga port.
When you power up the cpu press F8 key then enter in "enable vga mode" Then go to start->control panel->display->settings.
Change screen resolution to 1024*768 then apply and ok.
Then check.
But if num lock led is not on/off and left constant then you need to open cpu cabinet.
Refix RAM memory.Pull cmos cell from motherboard for 10 minutes.
Clean dust from all parts.
Reattach processor and it's fan.
Open motherboard from cabinet and try outside of cabinet.
3helpful
3answers
Motherboard display problem
Hear some any beeps to your motherboard. If your hear this beeps then motherboard will identify what is the loss connection of trouble of your MOBO.
If you don't then have to remove tor clear the CMOS by removing the Lithium Battery in it.
No any display & sound then i power on my PC my pc is intel 815t abit st6, red led is always on but no display? can any one help me??????
First check your num lock key led if it on and off when you press num lock then your cpu gives diaply to monitor perfact.
Then check your display connection from monitor to cpu.
When you power up the computer pressF8 ket then enter in enable vga mode.Then go to control panel -> display->property ->settings.
Then change screen resolution to 1024*768 then apply and ok .
But if you still not get dispaly then
-> Open cpu cabinet.
-> Refix RAM meory clean all dust from motherbord chip set .
-> pull cmos cell for 15 minutes.
-> Reattch ATX power supply to motherbord.
-> Refix processor it is bottom of processor fan.
Please rate my solution if it help you .
Thanks for using fixya.
Monitor is not on
Im gonna take it that "yup i'm hear the any beep" means you do hear a beep.
So first If it has an onboard vga card. remove the second vga and hook the monitor up to the onboard and try to boot.
Second try the Power Supply, make sure whatever power supply you use has enough to handle all the equipment in the unit.
If those two don't solve the problem, then you have a bad motherboard.
Led hd & pwr is on,fan cpu is runing, but monitor is not on, vga card was change but still no working
Fix your ram after cleaN IT AND ITS SLOT ALSO CHANGE RAM .PUT YOUR CMOS CELL FOR 15 SECONDS SO YOUR CMOS SETTIGNS ARE RESET.
Top Gigabyte Computers & Internet Experts
MegaByteMe
MegaByteMe
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
