SOURCE: PNY Optima Attache 4G
I had all the same problems and figured it out. Right click on my computer and go to manage, then select the disk management option. Right click on the drive and select partition. Then tell it to partition the full size of the drive and make sure you dont let it use the fat or fat32 options. It will then ask you to format when you partition it, use then quick format and it formats. Works good now. I did this on xp pro so I dont know if vista will be the same.
SOURCE: PNY Optima Attache 4g Flash Drive
Change the drive letter of the pny drive to another letter, different than that of your accounting package. Right click "My Computer" click "Manage" select "Disk Managment" right click the drive, select "Change drive letter and Path" and then change the drive letter to something not used on that computer.
SOURCE: how do I get my computer to recognize my flash driver?
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA the leads from your ((motherboard to your hard drive)) make sure they have a secure connections and are not faulty or just replace them they might be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions even something as small as an electrical fan and its lead can cause you problems or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free restart your computer then reinstall it this should activate found new hardware wizard hope this helps you
