Dont work display an no sound
You have described a power problem. the unit is not coming on.Are you using the proper PSA adapter on this thing? If using a generic one, make sure the polarity is correct. Most of these things are wired backwards as compared to other types of devices. Does it work with batteries? This is where to start on a diagnosis. If it does, the wires from the batteries go through the socket where the adapter plugs in. Try spraying contact cleaner into the socket in case it is dirty or stuck in an open position. One more thing, IF a generic adapter was plugged into it that was opposite polarity, it may have burnt a diode on the circuit board. (a microscopic one at that)
